February 1, 20188 yr Does it screw into the flywheel itself or are there nuts behind it? Just wondering if I need to buy a puller or not. Don't want to unscrew it then find I can't ride again until i remove the flywheel to retrieve fixings.
February 1, 20188 yr it is just held by two screws - no nuts behind. They may be tight/loctited in place, but not a good idea to hit the flywheel so I wouldn't recommend an impact driver...just a good fitting screwdriver.
