TXT Pro Sachs Rear Shock
The rear shock on my bike has stopped working correctly, it will only go down 2/3 the travel then hits a dead stop hard (about 5mm before the rubber bump stop)
Anyone else had this problem?
Not a whole lot of people repair a Sachs.Time to look for a new shock.Bent shaft, shock head damaged. Let us know if you get it apart.
3 hours ago, suzuki250 said:
Does anyone where to get one repaired?
Splatshop will be able to get it repaired for you
I’ve rebuilt the shock using the above video & info off the net, it was quite a simple fix.
The only bit I wasn’t keen on was drilling it to let the pressure out!
I will post some photos later :thumbup:
