January 24, 200422 yr Does anybody know an easy way to re-fit the chain tensioner on an 03 pro. just had the suspension in bits to re grease everything, and decided to do the chain tensioner at the same time . it took longer to put the tensioner back on than it did to re grease the suspension . i must be missing somthing (i'm sure that i could find lots of people to agree with that)
January 27, 200422 yr Glenn, Nightmare mate, been there with my 03. Tried for hours. In the end, replaced the bolt with a length of studding sticking out past the swinging arm, put the assembly on, followed by a thin bolt, studlocked then cut off the excessing studding (if you follow !) Not ideal, will never make taking it off again any easier, but it worked and lasted 9 months with no problems before the bike was replaced. I was the same, only took it off as I was servicing the suspension !! Linkless suspension - now that's an idea, no servicing !! maybe add a little 4 stroke motor, possibly a freely available 125 engine, Lets ditch the radiator & fan, is there a market !! John.
