September 23, 20188 yr Hi I'm looking at a 2016 Scorpa Twenty 300 and by looking at pictures of it it seems to have a switch in front of the tank, is that a map change, or what? If so are the modes on it dry and rain or something else? Also if one of the settings is rain, does it take much of the power away? Are there any other CDIs available that could add more maps to it/more power? Weird questions, I know but all answers are appreciated. Cheers
September 23, 20188 yr Yes it's the map switch for dry and wet conditions, It does make a considerable difference I've found but if you really want more power swap it for the later Dual spark CDI and it really livens it up, Make sure to use Part no 6416 if you change it, not from the 18 onwards models.
