November 21, 20187 yr Hi all Does anyone know where I can buy a flywheel puller from for a beta 80cc 2017? Thanks Steve Edited November 21, 20187 yr by Ste_g88
November 21, 20187 yr You might show location. Have you tried your dealer? Just curious why you would need one on such a new bike? Edited November 21, 20187 yr by lineaway
November 22, 20187 yr Author 7 hours ago, lineaway said: You might show location. Have you tried your dealer? Just curious why you would need one on such a new bike? Just bought the bike for my lad and 2 week later and it now sounds like bearings have failed on the crank...gutted to be honest.. can't seem to find a pulley for it
November 22, 20187 yr https://trialstribulations.net/index.php?main_page=product_infoandproducts_id=2989
November 22, 20187 yr 6 hours ago, Ste_g88 said: Just bought the bike for my lad and 2 week later and it now sounds like bearings have failed on the crank...gutted to be honest.. can't seem to find a pulley for it. Video with sound would be good and £34 for a simple puller is a bit steep. Are you sure the mains have gone, can you move the crank about from side to side by pulling on the flywheel?
November 22, 20187 yr Quite possibly the rivets on the side of the flywheel have worked loose. Rattles like a pig and sounds like the mains have gone. Hammer will fix it. Edited November 22, 20187 yr by crashmonkey
November 22, 20187 yr Author Ok well I've ordered a puller. Basically what happened is I got the bike out and the kick start had locked up..it freed off by pushing the bike back and forth. Then once I started the bike up it sounded like an old tractor so turned it straight off. The bike was fine when it was put away so I've really no idea what caused this. I'll keep yas updated though. Thanks for the advise etc
November 22, 20187 yr 2 hours ago, crashmonkey said: Quite possibly the rivets on the side of the flywheel have worked loose. Rattles like a pig and sounds like the mains have gone. Hammer will fix it. Hi there, is this quite common as my 16 Rev 80 feels like it's about to seize when it gets really hot ? Let it cool and it runs fine. Cheers
November 23, 20187 yr 15 hours ago, Ste_g88 said: Ok well I've ordered a puller. Basically what happened is I got the bike out and the kick start had locked up..it freed off by pushing the bike back and forth. Then once I started the bike up it sounded like an old tractor so turned it straight off. The bike was fine when it was put away so I've really no idea what caused this. I'll keep yas updated though. Thanks for the advise etc Check those 6 rivets that attach the 'outer flywheel' to the centre boss - hopefully an easy fix - good luck!
November 24, 20187 yr If the flywheel has come loose it may well be touching the inside of the flywheel cover, that’ll make a hell of a noise. So as crash monkey says check those rivets as well as the centre nut.
