Wont start
Hi guys n Happy new year..  4 Ride...i had a fall the other day bike went down in a stream..theres no water in the air box. Plugs sparking ok. But will only start on easy start thru the airbox...fur a few seconds. Im thinking its a fuel issue...any ideas.
good trend about this in forums "feb 18 4ride 4rt capaccitator/condenser"  about a bloke dropping his bike in a stream and it wont start  might help
Did you make sure there wasn’t any water in the fuel?
Might also try bypassing the bank angel sensor...  might be shorted and if so wouldn’t let it start and stay running.
Guessing you already tried the full throttle kickstart twice rest.
Good luck.
Yea tried the reset. N ye think the bank sensor could be at fault..its started only fur a few seconds. But in reality i was using body spray not easy start..i will get some EASY START tomoro n give it a go..if i can get it to keep goin n keep sprayin it, it may pull the fuel thru n run on its own. I was thinkin it may have got a bit o water in the fuel some way but a doubt it..tank never went under..
Bank sensor will stop the bike if it’s tripped but I admit I don’t know if it stops the fuel or spark.  If fuel then it could be the cause.
Good luck with that. Hard hats in the Motherwell area, look out for low flying cylinder heads ....
Bikes all running fine after a few squirts o easy start n a clean filter...put some injection cleaner thru it. Jist needin a wee run out now...
