monte a 315r Clutch spring bolts torque setting
Hi guys,
Firstly am trying to get a manual so will stop bugging you lot!!!
Secondly what is the torque setting for the clutch spring bolts (315r '98)
Thanks in advance
I worked to 8-10NM when fitting new dimpled plates to my '98 315R. Filled the case with Dexron III and she ran perfectly... no drag and a lovely light action.
Tighten the bolts in a criss-cross format to load-up the clutch mech evenly.
Edited by riffraffretro
Nice one Thanks for that, I've got the ELF oil so should be fine !!
Ok will do! Is dexron cheaper and easier to get than ELF?? Cheers
All the Elfs have gone back to ??Santas grotto to make next years toys!??Have you seen how they extract elf oil....?⚗️???
Dexron III is widely available and (in my opinion), does the job as well in the 315R - particularly when combined with fitment of dimpled plates - as the Elf oil. The 315's clutch is fabled for suffering with excessive drag... mine was unrideable until I changed the plates and reverted to Dexron III.
Hi yeah mine was pretty bad!! Fitted dimpled plates and am waiting for a new o ring to come before filling up and having a go! Hopefully will be on par with yours! I'll try the dexron in the near future and see how it goes.. Thanks
