03 290 Gearing?
I just got a 03 290 and I was wondering if it helps to drop down a tooth on the countershaft sprocket? I had a TXT280 before the Sherco and this change made 2nd gear very versitile. I am just concerned that the Sherco is only a 5 speed ,making commuting between sections slow . Has anyone tried this gearing change or anything else? Also do any aftermarket companies make sprockets for the sherco? Thanks JK
Jimmy,
Try it before you make any changes, I think that you will be very happy with the gearing. The 2.9 is NOT slow between sections, my boys and I have raced ours in local Hare Scrambles and have been VERY competitive.
The "02" had a very tall 1st gear and was much improved with 1 tooth lower on the countershaft sprocket.
Wayne
