GG txt 249 oil spitting out of exhaust with white smoke
What could the issue be? Piston and rings needs replacing? Crank seal?
Any other ideas? Cheers
Sounds like a crank seal. You can usually smell the difference between 2stroke and gearbox oil
Edited by faussy
Could the white smoke be in fact steam? I seem to recall reading that white "smoke" could be indicative of a head (o-ring) leak into the combustion chamber. Perhaps do a quick assessment of your coolant level?
As above, white smoke is usually water. It is possible that the cylinder head O rings have hardened up and are leaking allowing water into the cylinder. Have a check also on the clutch cover sight glass to see if the oil in the gearbox/clutch looks clean, or is a milky colour, indicating that the water pump shaft and seal are leaking. Bye, Peter B.
He says its spitting oil out the exhaust, yet you guys are convinced its water? WTF
second that on the crank seals, if there is il coming from the exhaust.
Edited by arnoux
Oil smoke is blueish, not white ?
Not when its burning it in large quantities from the gearbox
Edited by faussy
