Gas gas 300 txt pro 2005
Help needed...bike starts ...runs for few seconds and cuts out
Hi yes , that's all been done, thinking definitely electrical, starts first kick , the dies after a few seconds
If this problem just started after you have worked on the bike and this bike has the Dell'orto carb perhaps you have put the floats in upside down.
Disconnect the kill switch as a first point of investigation.
Have you replaced the pipe that links the two overflow /breathers on the sides of the carb?
Hi no , theres no pipes on them and its been running like that fine for last year and a half
done all of the above, runs nice and crisp , then cuts out
done that , still the same
No not that... thanks
breather vent in the cap blocked?...try removing the cap and see if that sorts it....do you have a fuel filter fitted in the line?...I kept getting an air lock in one of mine...changed the position of it and it sorted the problem...
good luck!
  • 2 weeks later...
