March 27, 20197 yr Hi looking at the s3 cylinder head for my 19 gasser as iv been advised to look into but im just wondering what exactly does it do and what impact it would have on the perfomance of the bike. Thank you
March 27, 20197 yr Depends on which insert you fit, lower compression should tame it down a bit, higher more snappy
March 28, 20197 yr Its suplied by GGUK FOC for the new 250 GP as a clubman friendly upgrade. Edited March 28, 20197 yr by nigel dabster
March 28, 20197 yr Author Ah right dont mind how the bike feels at the moment to be honest so il leave it as it is.
March 28, 20197 yr 13 hours ago, nigel dabster said: Its suplied by GGUK FOC for the new 250 GP as a clubman friendly upgrade. Auf wiedersechen pet ?
March 31, 20197 yr Not used one on the Gasser but got on my KTM 300 EXC... as above... different inserts for different compression ratios. Stock trials (my 07 250 TXT Pro) head looks like a higher CR than my KTM (15 300 EXC). More compression more punch up to a point, I. Tried the high-high insert in my KTM and it was too much, would cough stall like a 4T at low revs... ok for MX and just misbehaving but not general enduro cross country stuff. General anecdotal evidence.
April 1, 20197 yr I would be surprised if the enduro bike was not running a higher spec of tune than a trials bike, some of the compression ratio also comes from the piston design and the bore and stroke. It's not just about changing the insert, by doing that you may have gone massive on the compression ratio !
