May 17, 20197 yr Having issues with my neighbours 2006 250 TXT Pro. Can only get 1st, N and 2nd gear. Some times after it's been going for a while 3rd is available. I've changed the selector spring and top hot. Next on the list is the ratchet selector but is there any guides on how to replace this or is it easy to get to? Also does it sound like the adjustment screw would solve this?
May 17, 20197 yr Adjusting the Eccentric screw may help this condition. https://www.youtube.com/watch?v=G55FU27Z9bU or may be bent shift forks.....
May 17, 20197 yr You are looking at splitting the cases and replacing the shift shaft assembly. Not something to do if you have never split a motor. Search Jim Snell You tube video`s. Edited May 17, 20197 yr by lineaway
May 17, 20197 yr Author Thanks for the relies! Hopefully the adjust screw will work as I don't fancy splitting the case
