Engine paint for a Gas-Gas Contact JT25
Hi I have a 1995 Gas-Gas Contact JT25 and I wanted to repaint the engine, but I'm unsure of the colour it should be does anybody know the correct colour codes and who supplies suitable engine paint.
Thanks
Nikki
RAL 3020 near enough. Needs to be heat resistant though, so you may want to go for red engine block enamel. Amazon probably a good bet. Reasonably good match, especially if you paint the full component. Most older GG's will have lost a fair bit of paint by now.  If you want a perfect match, get original matched using paint chips at your local automotive paint supplier. 2K  car paint most hard wearing but not cheap & needs hardener / thinner, then spraying on.
Many thanks I'm looking on line now for it.?
