January 18, 200620 yr Is this Hebo flywheel weight for the Pro an alternative to the one sold by GG UK or is it just for a different model than the one shown on the GG site?
January 18, 200620 yr Author The Hebo one is from BVM, looks quite different from the one on the GG site, the Hebo one looks as if it is held in place by one central bolt but the GGUK one has a hole about 50mm diameter in the middle and is held on by 2 M6 screws.
January 23, 200620 yr What, so that kit is to actually make the flywheel heavier ?? to make for smoother power delivery ??
January 30, 200620 yr couldnt adding more weight be a bad thing?? as you are affecting the balance, between the flywheel and the counterweight, (yes i know the counter weight is alot smaller/ lighter anyway, but are you not putting extra strain on your main bearings heading for an earlier bottom end rebuild? Are these a larger problem with them?
