August 17, 20197 yr What is the best fuel tank sealer to use on a leaking fiberglass fuel tank? Does anyone make an aluminium fuel tank that fits under the fuel tank of a Montesa Cota? Thanks
August 17, 20197 yr Do a search on any of the motorcycle forums and you will find that Caswell's fuel tank sealer is the most frequently recommended sealer. I have used it on numerous fiberglass tanks with great success. Just follow the instructions on tank cleaning and application. See https://www.caswellplating.com for details.
January 3, 20206 yr I’ve sealed four tanks with Caswell and I’ve had no leaks. Edited January 3, 20206 yr by Captwk
