August 30, 20196 yr Hi all im in need of some help iv just restored a red Montesa 200 and I need to know haw to set the timing any help would be much appreciated also dose anyone know were I could get a workshop manual thanks monty Edited August 30, 20196 yr by Monty 21
August 31, 20196 yr Timing is 2.00 mm (0.079") BTDC with the points set at 0.35 to 0.45 mm (0.14 to 0.18"). There is no Montesa workshop manual. The closest you will find is the Clymer Service and Repair Manual for 1965 to 1975 Montesa 123 - 360cc Singles. They pop up occasionally on E-Bay and will suffice for the 1976 through the early 80 models.
