September 19, 20197 yr How do the Sidi trials boots compare size wise to other brands? Would I be correct in thinking they come up a little on the smaller side?
September 19, 20197 yr I went from a 45 gaerne with thick socks to a 44 sidi with thin socks because the 45 sidis just felt very bulky, outwardly. Id kind of agree with you though and say they are a more snug fit than a 44 gaerne, but it could most likely be because they are a less flexible boot Edited September 19, 20197 yr by faussy
September 19, 20197 yr Same as pauls320 my gaerne and sidi both 43, sidi is a stiffer boot so will initially feel a bit snug and does soften a touch which aids comfort.
September 21, 20197 yr On 9/19/2019 at 9:57 PM, section swept said: Theres no comparison to actually trying on before you buy. This is the only way, ditto helmets. Nether can be fitted to you over the internet.....
September 21, 20197 yr On 9/19/2019 at 10:30 PM, madmostin said: What boot would fit a larger calf muscle. Asking for a friend. ? size 45 i think gaernes as mine are always done up tighter on the straps at the top, but i refer my friend to the answer above? Edited September 21, 20197 yr by nigel dabster
September 23, 20197 yr On 9/20/2019 at 7:30 AM, madmostin said: What boot would fit a larger calf muscle. Asking for a friend. ? size 45 I'm size 45 and "ample" calves. Not Forma boulder. They only just overlap on the calf for me. The old Alpine Stars were OK on my calves but I haven't tried the current stitched-on-sole Alpine Stars
