2019 300 EVO; what to look for
Hi, I'm new to the sport, like really really new. Long time motocrosser, good solid 40+ expert rider (almost 60 actually) but a complete and utter spode on this thing. And by this thing I mean a 2019 300 EVO I picked up on a whim this summer. I'm a bit heavy at the moment (225) and installed stiffer springs and adjusted my handlebars a bit further forward. I plan to dump the break in gas (40:1) and use the recommended ratio. Right now it both pings and burbles and blows lots of smoke. Basically I'm wondering what things I should look for, things that break or need modification. Good hop ups, jetting specs, etc.  Basic stuff. Any input would help
Thanks
Even 80:1 using good quality synthetic oil my ‘19 evo puts out a lot of blue smoke as it seems to collect in the pipe if your not riding it hard.
 Go to a 48 pilot jet. The stock main should be fine. You are killing your exhaust an early death at 40 to 1 unless you are road racing.
8 hours ago, b40rt said:
I'd run it at the recommended ratio for a tank or two before considering touching jetting.
What type of oil would you use :D
Hey thanks for the replys, been away from the computer. Yes I know the 40:1 needs to go. Manual says 60:1 but I thought some else also told me 80:1 which I have no problem doing. I was planning on trying the mix before jetting but it definitely pings off the bottom so I might look at the 48 pilot.
As for oil, I prefer Crisco
Partial to sesame oil myself but that’s a different application. Beta’s are notorious octane pigs. If you want it to run properly feed it the good stuff. You can also get a low compression head which reduces the octane requirement somewhat and makes the 300 a little less hyper though it will occasionally remember it’s still a 300 and surprise you if you’re not careful with the noisy grip.
