January 23, 200620 yr Hi,wondering if any-one can help.Ive got an early 1995 250 Gas Gas which has crankcase cooling,I seem to remember at the time the later models had it blanked off as they had trouble with bearings spinning in the casing.(I could be wrong)My bike has developed a water leak by the banjo bolt where it enters the casing as the casing has corroded away any-one any ideas if can be blanked off or if somthing needs doing in side of the engine as well.Or any ideas on repairing the casing? Many thanks
