December 22, 20196 yr Hi, has anybody used an inline fuel tap to bypass the problem of turning the fuel on with gloved sausage fingers ?
December 22, 20196 yr drill a small hole in the tap & use a small zip tie or key ring to give easy purchase. Quite easy mod. (BTW Be careful if you decide to unscrew original tap from tank (M6 screws). Captive nuts moulded into tank can let go.& you'll have a bit of a carry on to sort it all out. You'll also need some fancy epoxy to re set them)
December 22, 20196 yr Just drill a small hole in the end of the lever and put a small cable tie through it. problem solved!
