348 front hub seals
Anyone know where i can get a set, they appear to be uncommon sizes, although i have put new sealed bearings in so could refit the old ones.
I don't know if my 349 ones are the same, but I seem to remember I found them on ebay by searching by size
I just fitted 2RS bearings and reused the old seals (probably pointlessly). Modern bikes don't have the seals and provide what most seem to regard as adequate bearing life.  You'll be taking the wheels out after every trial anyway to allow the brakes to dry (if you want to preserve such braking power as there is) so the bearings will get a chance to shed water too.
Bearing Revolution (bearingrevolution.co.uk) lists the 21x35x4 seal. They do not list the 24x35x4 size, but do show a 24x35x6.
