Vertigo 9V Battery Capacity?
hi.
The startup problem was well resolved via the forum.
Mister peterb Thank you again.
This question is 9v battery capacity question.
I need to use a 9v rechargeable battery  Can I charge my battery while starting up?
And 9v rechargeable battery capacity How much should I use?
at Least  200mah? 250mah?
Can I use 1000mah?
(16 Vertigo Combat 300 )
You can charge the 9v battery before you fit it to the bike on a purpose made battery charger. The battery must be a nimh type, nickel metal hydride rechargeable 200, 250 or 300 mAh. Theoretically a 1,000 mAh should work, it would store more electric charge than a 200 mAh. I used a 300 mAh for a long time. Bye, Peter B.
