Beta Electrics & Water
re the ongoing debate on putting drain holes in the flywheel cover and cleaning out after every ride .....
my mate suggested also using ignition sealer spray.
Anyone else use this ?
What sort's best ?
WD40 any good ?
Hi folks,
Whats it to be then.............? WD40 or the stuff you spray when your up the telegraph pole ?
I thought WD was ok for electrics..........now very confused.
I used WD 40 to get the sticky remnants of some old Technosel off the swinging arm on my Rev 3, so there's definately something in it. I hope it doesn't affect the sealant on the coils though, because I've started to blather mine in WD 40 when I take the flywheel cover off to wipe off any moisture. ;)
P.S. I had the stator plate fail on me a while ago, took the bike to <mention of this company is not permitted on Trials Central> at Royston who had the plate re-furbished and drilled the cover. Since then, I've had no bother, touch wood, although I religiously take the cover off and dry the inside after I wash the bike. :P
Ah! Another fine testimony to the good effect of gravity removing water! Imagine that!
A treatment of clear high temp engine enamel will help protect against water entry to the electrics.
There is a moisture displacement called Corrosion-x that is widely used in aircraft and marine that is touted as safe for electronics. It also lasts longer than wd-40 but is more expensive. :P
WD40 is mostly kerosene.
Parrafin to you blokes.
You can smell it.
Certainly a solvent.
The spraypaint thing works fine, but I don't know why folks are stuck on clear.
I imagine any color would do.
solvent?
does this mean that it's not ok to use, what about pro care, that displaces water and claims to be safe on coils.
bob
I never had a problem with 4 rev3 ive had. I use silicon on the cover and remove monthly to clean and reseal.If ridding in extreme water conditions naturally take the cover off to dry once home.
Just an idea not sure if it will work but wrap sellotape around casing while the cover is off and apply a little grease then put the cover on and put silicone around the edge of it and allow to set. after it has set remove the cover and sellotape and re-fit the cover the silicone should still be attatched and form a nice seal.
P.S sorry if it doesnt make much sense i thought about it whilst doing my homework Damm stuff hate it
Hi again,
thanks for all the comments.
Sounds like WD40 might not be ideal for the electrics and I'm not keen on spraying with paint or enamel.
I'll track down some proper ingition spray.
I might also explore Essex Riders idea of effecting some kind of seal.
Must be better to prevent than cure.
