June 24, 20206 yr Hi All I recently bought a gas gas Txt 50 for my son starts and stops as it should but seems to be lacking power I have checked the clutch doesn’t seem to be badly scone Do you think this could be through bad.. gear oil ??
June 24, 20206 yr No, do you have clutch slip? do the revs rise yet it goes no faster? that's clutch slip, being 50cc it's never going to be a ball of fire in best form.
June 24, 20206 yr Author Yes that’s exactly what’s happening how can l go about fixing it Edited June 24, 20206 yr by Chrisygittings
June 25, 20206 yr Chris, you wouldn't be a Chris Gittings I knew from TDC would you? Edited June 25, 20206 yr by jonboy883
June 25, 20206 yr 17 hours ago, Chrisygittings said: Yes that’s exactly what’s happening how can l go about fixing it Check all adjustments are as the manual and if so replace the clutch frictions.
June 25, 20206 yr My son had a TXT50, and I seem to recall that it had a dual-function clutch arrangement; is there a clutch lever as well as an automatic clutch mechanism? On my son's bike I removed the clutch lever and replaced it with a rear brake (and removed the rear brake pedal). This was done to be an easier transition from his OSET which had its controls setup that way. Perhaps your clutch level mechanism is preventing the automatic clutch from fully engaging? And don't expect the TXT50 to do big walls and splats. Use it to teach the basics and how to start a gas motor, how not to get burnt, etc. Clutch control too. And start shopping for the next bike right now. I went with a GG TXT80 but it too was so down on power; but still a good platform to learn gear selection, etc. I have no experience with it but I've heard good things about the Beta Rev80 with the big wheels. Have fun. Edited June 25, 20206 yr by d2w
