September 22, 20205 yr Hello it is all new for me just bought my first bike Sherco 250st 2009 and it struggle to start first time every day after 5 minutes of kicking bike( with choke with out with throttle open ) it will get running and then it starts every time first kick it is only after a night have cleaned the carb but still the same anu ideas Thank you
September 22, 20205 yr Not sure from your post are you opening the throttle or not when trying to start from cold with choke on? Seem to remember delorto choke isnt effective if the throttle is open at all. Lift choke and kick it with throttle fully closed till it fires should only take one or two kicks.Never had a sherco but had other bikes with delortos on.
September 23, 20205 yr How are you sure it’s lack of fuel ???? Carb issue. Did you put fuel direct into the cylinder & it started first time confirming it was a fuel issue. Could be ignition prob, reduce / half the plug gap & see if there is an improvement.
September 24, 20205 yr Author 17 hours ago, Davidtwinshock said: How are you sure it’s lack of fuel ???? Carb issue. Did you put fuel direct into the cylinder & it started first time confirming it was a fuel issue. Could be ignition prob, reduce / half the plug gap & see if there is an improvement. Hello problem solved previous owner have put extra quick disconnect valve on fuel line and was not letting fuel thru as pipe was very long 35cm yesterday replaced with 10cm new line and today started first kick Thank you
September 24, 20205 yr Author 17 hours ago, Davidtwinshock said: Hello problem solved previous owner have put extra quick disconnect valve on fuel line and was not letting fuel thru as pipe was very long 35cm yesterday replaced with 10cm new line and today started first kick Thank you
