September 25, 20206 yr So,, back in the 90's I rode around with an old Montesa 125cc. 2 weeks back I fell the urge to get a new one so I bought an 2018 TXT 300 (which in hindsight is way to powerful) Of course it came with issues: 1) push out gear fluid thru the plastic hose, drained and refilled 3,7dl but still pushes out oil. 2) very hard clutch, new clutch discs 1 day before I bought it, but it's really hard. Nothing lika the MC that I normally drive, I thought that a hydralic clutch would be easier.. Any thoughts? (english is not my native so sry for any bad wordings) Edited September 25, 20206 yr by eat
September 25, 20206 yr You need to pull the clutch cover and pull out the center bolt of the clutch basket and make sure it is a hollow bolt. That is the engine vent and you have to have the cltch basket in specs. Edited September 25, 20206 yr by lineaway
September 26, 20206 yr These 2 videos should help you the clutch can be very light if the plates measurementment is correct.
