October 23, 20206 yr Being a bit of a short a***, I'd like to lower the suspension on a 4ride. Anyone had any experience of this or have any suggestions? Also would there be any issue in putting forks and shock from a 4rt on it? Cheers
October 24, 20206 yr All of the linkage bits i checked have the same part numbers so I would think that the ether of the 4RT shock options, Showa or R16V, would fit and I would guess the same for the front Showa/Tech... Edit: Yes the front triple is the same part number as well so, yes the front Show or Tech's it would fit. Edited October 24, 20206 yr by jonnyc21
October 24, 20206 yr You could drop the forks through the yolks an inch and back off the rear spring to match, but how about taking a bit off the seat foam?
