October 29, 20205 yr Hello, new to this forum and have searched this subject but didn't find any info specific to my issue. Bike runs Ok on level and uphill but starves for fuel and quits on descents. It initially runs fine on downhill but after a few seconds runs out of fuel, pulling the choke lever brings it back to life. So, it looks to me like the float level is too low and as it runs downhill its burning off enough fuel to starve. I've pulled the carb and checked the float level. Spec is 23.5 to 24.5 mm. It's currently at 23.1 mm. So the difference between actual and high side of spec is about 1/8" (old school). Thinking this is likely the issue but wondering if there is anything else i should be looking at while its apart. Pain to get access to the carb and hoping to only have to do it once. I did notice there is an O ring around what appears to be the passage for the main jet (?) or other. The O ring is in excellent condition as is the interior of the carb. Anything else I should be looking at?
October 30, 20205 yr It would help with diagnosis if you were to either say what carby it is or post some photos. They were and are a very rare bike so not many people would know what carby they came with. Also there is a Montesa (Cota) forum. This is the Sherco forum Edited October 30, 20205 yr by feetupfun
October 30, 20205 yr Author Oh, sorry. Will move to the Cota forum. The carb is a dellorto phbh26sd. Think these were pretty much the standard on most European machines so any insight would be appreciated.
