April 19, 20215 yr Hello all I have a 2015 factory 300 would anyone know what spark plug I should be running in it? Many thanks
April 20, 20215 yr Author 2 hours ago, reggie said: BR7ES That's great thank you. I think mine has the wrong spark plug in that's why I asked.
April 20, 20215 yr Author 2 hours ago, reggie said: BR7ES Just found the manual and it's saying BR7ES are for 125-200 and BPR7ES are for 250-300 is this right? Many thanks
April 20, 20215 yr BPR7ES is projected tip, but same heat range as BR7ES. Either spark plug will work fine.
May 3, 20215 yr Author On 4/20/2021 at 9:21 PM, wheelieman14 said: BPR7ES is projected tip, but same heat range as BR7ES. Either spark plug will work fine. Thanks for that I'll get a BPR7ES and try it this weekend. I've only just got the bike and it had a BPR5ES in it where my old 2013 Factory used a BPR7ES this is why I was asking about what plug should it have. Thanks All
