November 21, 20214 yr Hi all, Been out today on my 315 it was snacking a bit but running ok ,then it just died restarted but soon as under load died again ....repeat !!! Any ideas ?thanks
November 21, 20214 yr How does a bike Snack? Clean carby and try again but sounds like HT coil if it runs okay without any load.
November 22, 20214 yr Snacking issues? Try a Snickers - could well cure the issue! Snickers 'You're Not You When You're Hungry' TVC - AdNews - Bing video
November 22, 20214 yr Author Haha snatching I meant !!! Although if I like a snicker bar !!! Th x will try carb clean then coil ! Btw was ok for a while until warmed up????
