December 2, 20214 yr The fuel hose on my Long Range Tank is leaking right where it exits the shut-off valve. I can't see any way to get in there to release it so I can replace the hose. Does anyone have any ideas on how to get to it or how to take the fuel valve out? THANKS FOR ANY HELP!
December 3, 20214 yr Gently pry off the knob used to turn on and off the fuel from the long range tank. You will then be able to see what you need to do. If you require a new petcock the part number is 27.81083.000
