Gasgas petrol tank expanding
Hi All
The petrol tank on my Gasgas gp 280 has expanded to the point we’re it is almost impossible to get it in.
I was wondering if the 2012 aluminium tank would fit ,it looks to be the same apart from it being a little higher
We’re the fuel cap sits.
Has anyone tried this modification,  I don’t really want to go spending on another plastic tank for it to do the same
Any information would be much appreciated
Cheers
I had the same problem with mine. I found out that the fuel I had been using had ethanol in it and after changing to a non ethanol fuel, the tank over a period of time returned to its original size. Sounds crazy but it's true.[10% ethanol]
Edited by sherpa325
The fuel petcock is different on aluminum tanks so if you go that route you'll need the petcock too.
 Modern Ethanol laced fuel causes all kinds of problems with plastic tanks, O rings, seals ,etc. Solution is to remove the ethanol from  the petrol. Easy to do, as Ethanol readily co mingles with water. Slight downside is that you've got to chuck away the ethanol you've removed .
Check it out on You Tube.
And the fuel you are left with is damn poor stuff, looses about 3 points of octane rating. Best to just buy proper fuel to begin with.
