February 4, 20224 yr Hi can anyone send a close photo of the master ajp clutch cylinder with the rubber boot covering the spring and pin mine doesn't attach to the master cylinder so ends up folded and not covering the pin please see photo
February 5, 20224 yr It may be that the little rubber boot has swelled due to oil contamination or that the wrong one was fitted before. If you look at the Jitsie kits on Splat Shop website make sure that you chose the one for your master cylinder otherwise it will not locate in the groove in the master cylinder and stay in position.
February 5, 20224 yr I thought the boots were the same for each (mineral oil or fluid) you have a mineral oil master cyl. I use a socket to push the boot in rather than chasing it around with a couple of screwdrivers.
