February 12, 20224 yr Hello, ive got a 2017 gasgas txt which has a hole in the plastic tank. I am looking for a replacement and was wondering it a 2012 tank would fit ? thank you
February 14, 20224 yr 2012 is alloy. I think it will fit, but your tap won't. You can buy a new tank btw
February 17, 20224 yr Hi there GMW386 The 2012 alloy tank will fit perfect,I fitted one to my 2017 GP after the tank had swollen due to ethanol in the petrol. As suggested by Faussy you will require a new petrol tap,also I think the alloy tank looks better than the plastic cheers
