Beta rev3 2000 rear shock bolt
Does anyone know if the lower shock bolt and special nut on Rev3 2000 is the same dimensions as on the newer beta rev3 models 06, 07?
If you go to the Beta UK website, parts finder Rev-3 with the year as early as it goes, select suspension, it shows that the top and bottom bolts have the same parts numbers for 4 & 6 which is 11.65022.000 and says that it goes back to 2001- the same if you select 2007.  I'm pretty sure that they were the same for all years, but give Beta UK a call if you want to be sure.
Hope this helps!
