4 rt oils and service intervals
Hi folks,
UK post: Apart from the montesa recommended slikolene for the engine and elf for the gearbox what other decent alternatives are used?
I've read a few different hours for the engine and gearbox oil changes, for a bike that is not used in competitive trials (does it matter?) what would be a reasonable interval.
I read on a FB group, that an owner never changes the engine oil filter (not once in 10 years of ownership) - but just changes the engine oil, twice a year and gearbox oil yearly
He used it for Clubman trials 2-3 times a month and did the airfilter after every event in summer.... and only monthly in winter
His bike was fine and just ran ok, for the last 10 years, despite never having changed the oil filter
I believe that a good reason to change the oils more often than FB Group man ( or women ) is that having a look at the drained oil lets you know if there are issues with the bike.
50 hrs running seems a reasonable time for oil changes (motor and box) if you want to keep the oil golden.
I can then use it in my Honda 90 cub :)
I don't disagree at all
 I waited to the 6 month mark to change out the Elf oil. I went to the Nills trial clutch oil. The Elf came out looking terrible. I sure regret waiting too long. On my second change with Nills. Starting to look clean again.
 My employer changes his oil yearly. Seems his bikes could last longer if he maintained them more often. 2 17's, 4 16's and the other 6 05's are plumb worn out.
I have stayed with very clean motor oil. Changed every month or two depending on use.
I think it pretty dumb to run any engine in old oil. Yes it's expensive, £10a go?2 pints of beer?? The oil breaks down and loses its protective ability not to mention circulation all the debris it might hold in suspension. On a £7k retail price bike.
I swapped oil every 16hrs, filter 32hrs
If engine oil came out looking golden...if, it would be fine to use in my old Honda C90
If it looks black after 50 hrs use, I would be pretty worried about that low stressed engine
Do most people change engine oils at 15 hrs?
 Yeah, the engine oil is cheap. My son just paid 70 dollars for a bottle of Elf in the states. That is why I switched to Nills.
  • 2 weeks later...
After much consultation with machinists and mechanics, I went with a 5 gallon pail of Dexron THF1000 hydraulic fluid. To be fair, I changed it out several times immediately, for a "base line" test. It seems to work same as the ELF 740.
Engine oil: generic synthetic 10W-30.... change out every ten hours on my meter; such a small amount of oil for a high performance engine, with the low cost of the 5L jug of oil, it's a pretty forgiving investment.
