September 20, 20224 yr Hi Guys out there, I am working on my Amal L2627, it looks like a Amal Mk2 and the gasket seems to be the same (by the looks of it) Could anyone confirm befor I order, would be great!!! Regards from Germany
September 20, 20224 yr Looks to me as a Spanish Mk2. All Spanish Mk2´s I have seen are 2-stroke carbs. Body and throttle valve originally were made of zink so they will wear together and replacements might be needed. Think they do the valves in a a different material nowadays so it is worth considering. Whatever you do make sure you have the correct parts for your carb. Lot of parts around that are lookalike but will deteriorate the performance. If very expensive you may have to consider a replacement carb perhaps from a different brand.
September 22, 20224 yr This is a very good source for carburettor information and spare parts. https://surreycycles.com/
September 26, 20224 yr little about amal carbs https://static1.squarespace.com/static/547e5122e4b0193d67f28396/t/5854ddf6725e25b3b4c06d52/1481956877861/Amal+MK2+Carb+Manual.pdf
September 26, 20224 yr Author 4 hours ago, carl ekblom said: little about amal carbs https://static1.squarespace.com/static/547e5122e4b0193d67f28396/t/5854ddf6725e25b3b4c06d52/1481956877861/Amal+MK2+Carb+Manual.pdf Wow... that should help with all upcomming questions!
September 26, 20224 yr Note that Mk1 carbs spare part numbers often start 622/628 while Mk2 often start 2622/2928 and they are most often not interchangable. "Things to consider" is one important paragraph. Also note they changed the jet holder. Think it was around 1970 (from memory, not sure) Edited September 26, 20224 yr by carl ekblom Spelling error
