September 27, 20224 yr Morning guys getting round to refurbing my 1998 Beta Techno which since it is rarely used has been a bit ignored in the frame department. Could anyone tell me what the part codes are for the linkage bearings? Got a ridiculous amount of slack there Or is it a case of just getting direct from Beta and paying up 😅 also the rear brake is non-existent, tried bleeding and doesn’t seem to hold pressure for any length of time so think it is due a master cylinder…if anyone has one or can direct me towards one that would be good, if not it’ll also be a Beta job ££££££ thanks!
September 27, 20224 yr i picked this PDF up off the net when i has a 1999 techno, you should be able to google somewhere the 1998 parts diagram, you can then drop the parts numbers into Beta UK's parts finder on their website (i assume some version of this is avialbe in other countries). anyway this PDF has been annotated with bearing numbers (not by me) 1999_beta_techno_250_and_270_parts_manual.pdf
September 27, 20224 yr If its bad you will need the bushes too. Take it apart and you should be able to see the bearing numbers still.
