February 27, 200620 yr Just thought i,d dip into the Trials Central knowledge bank and ask,TOP TEN TIPS for mods on a 05 290.Riding -maintenance-tyres-ideas -ect.Please dont say- buy a beta/gasser/mont
February 27, 200620 yr Apparently sherco's go well with IRC tyres on them However dont know much about them so cant really say much else. Change the footpegs as the standard ones are horrible, trialcast or hebo ones, or if you really want to titanium raptor racing ones!
February 27, 200620 yr Quite a lot of the stuff you can get for gas gas fits sherco , trick bolts , fork protectors , keihin Carb i think ect dont really know about anything else.
February 27, 200620 yr I wouldn't bother with a kehin as the dellorto set up is very reliable and unless you are always feeling like you want more power (I doubt it) I always liked Boyesen reeds, a VX plug, make sure you have a 33 pilot, swap carb top bolts for 4mm llen head (not thread) change the air filter the same to 4mm (then a 4mm allen takes the lot off, keyhole the radiator cowl bottom clips, make a new clutch hose, modify a montasa disc gaurd to fit, fat bars , is that 10???
February 27, 200620 yr to improve power you could put a keihin carb on it i think, polish the ports, put a high compression head on, different gearing, run race gas and many other things which im sure people will add which will make it alot more powerful
February 28, 200620 yr Every single bike has them and for our gas, super unleaded petrol 98r0n(?) it really is spot on, or very close. Everywhere in the uk is at sealevel in real terms as well so altitude never plays a part. IF there seems to be one thing which seperates the UK and USA trials communities then its our lack of carb fiddling and jet changing. In fact 99% of riders never change jets and 1% never adjust the carb mixture or tickover ever. What is the altitude of the TTC by the way?
February 28, 200620 yr Use your lady's nylon chopping board to fabricate a rear disc guard. Nigel? more info on the clutch hose please
February 28, 200620 yr i have figgured that im going to be out of riding for a bit andsaw that my tyers were getting round and my sprockets are going. what is the better one to replace as i dont get money that easy
February 28, 200620 yr Author Cheers boys,i thought i would get a few ideas.Nigel,more info on the clutch hose mod please.TA
February 28, 200620 yr Author should have looked,but in the service manual[big sheet of glossy paper] it says the pilot jet IS 33 as standad.is this correct?
February 28, 200620 yr The front brake and clutch are the same hose( I think) clutch needs to be about 1 " longer gives an easy turn and hose not tight. saw an 06 with one at wallace so may still be a good mod.
February 28, 200620 yr Thanks Nigel, I'm not sure about TTC's elevation but I'll look. I'll be there in a couple of weeks and I'll try to remember to look at my GPS. The reason I was wondering about the pilot jet is because of a strange problem I'm having with my 2.5. After it's warm if you let it sit for about 5 minutes it doesn't want to start back, sometime chokeing works, sometimes it doesn't and you have to kick your butt off. I'm wondering about the pilot jet being right. It seems to be fine other wise.
February 28, 200620 yr i have figgured that im going to be out of riding for a bit andsaw that my tyers were getting round and my sprockets are going.what is the better one to replace as i dont get money that easy <{POST_SNAPBACK}> Get the chain/sprockets. You can ride until the tyres bald, but at some point the chain and sprockets will cause you problems.
February 28, 200620 yr i found this out the hard way when i brought my fantic and didnt check them before i rode off. This was the first trials bike i ever had and i tried a steep short climb and the chain turned on the sprocket and i fell back down Change it before this happens (it hurts and sounds terrible) I have a talon radialite sprocket on my bike and its still fine and i brought my bike last year!!!
