2003 Beta Rev 3 Barrel gasket dimensions
If anyone has a barrel gasket lying around can you please measure up the dimensions as I’m trying to cut one out of gasket paper.
 Thanks
Put the barrel on the paper, then draw around the cylinder. Cut that out with a scalpel or Stanley knife. Then put the part-made gasket on the barrel and use a small ball-peen hammer to gently tap around the periphery and the ports to cut the rest of the shape.
