September 3, 20233 yr Hello everyone, I did search the site and did not find anything relevant, so I apologize if this question is a repeat. I have a 1997 gas gas jtx 270 (i think, might be a txt?) either way the gas tank is toast, it is cracked and has a hole in it. As we all probably know HDPE plastic is nearly impossible to repair. ( I did try epoxy) So I need a replacement. I have searched online a fair bit for a replacement tank with no luck. Does anyone know where I can get any sort of tank that will work? Will tanks from other gas gas models and years fit? Are there aftermarket options? Has anyone used a generic tank of some kind? Any help or leads would be greatly appreciated. Many thanks, Isaac
September 4, 20233 yr Try Trials Bike Breakers UK or Allen’s Used Trials spares. Both on F/B. For a new tank try John Shirt Motorcycles who was the importers.
