October 21, 20233 yr Hi Chaps, I received a faber frame mk4 for couple weeks. What lenght are you using for The rear suspension?
October 21, 20233 yr I had a C15 with a faber frame. I used NJB ultimates they were length adjustable so you can set at what works best for you. Sure they were set at 340mm Edited October 21, 20233 yr by timdog
November 7, 20233 yr Author What means With 40lbs or 50 lbs on shocks is it rider weight? To specified something
