Ty 175
We have a TY 175 with a cylinder that is bored out to the max needing a new sleeve
Are sleeves avaiable here in the US for this machine and how much $ would I be looking at roughly?
sam
Edited by Sam
sam
Firstly are you sure that larger pistons are not available. Genuine Yamaha pistons go to 1.0mm oversize. Other brands of piston larger.
Resleeve should be able to be done in the US and cost about $200US to $250US (parts and labour not freight). Costs $300 to $350 Australian done in Australia.
Try Bob Ginder at B&J (www.bjracing.com ??) He will probably do some nice proting work also.
Look at Wiseco, but they don't list the TY175 anymore. The last one I got was listed for a DT175 of same year, piston appears same.
Sleeves: LA Sleeve might have. Or, just go on ebay for a good used cylinder andhave that machined up. Likely to be much cheaper if you are not in a rush.
kcj
Thank you for the replys, I'm going to try and get this bike running with out putting a whole lot of money in it!
sam
they tend to rattle, and run ok even with loose bore. don't recall, but I think spec is .0015 to .002, but I've had one running ok that measured at .004 loose. Depends on the taper, and if the bore is damaged or just worn. Not recommended, but you could get it back together and running with a new set of rings, then watch for a better cylinder as time permits. Or a whole second engine, go through that at your leisure time.
Im selling mine and still have the workshop manual, if you can gimme a rough idea of what section etc it would be under in the manual i could scan in the pages to help you fit the parts
Eddy,
what are you selling?
sam
This bike was basically given to me, but in a basket!
sam
Selling my TY 175, runs perfectly but im in the UK
Sam,
I think all the links I sent you the other day were for a TY250. Try THIS
Gaby
And, THIS
I know someone working in the middle UK, home is Scotland, looking for a 175. mail me off line and I will send you his email address. tks, kcj
You have a PM m8
