2004 Rev3 200
250 is a champion N7YCC think its probably the same. Some recommend a N5YCC think it burns slightly hotter.
I have just bought this bike and it has an NGK BP6HS fitted and that plug is a lot shorter reach than the Champion N7YCC. Is the wrong plug fitted or would there be good cause to fit the BP6HS ? Could it be to lower the compression and smooth the power delivery?
Edited by Dab Myster
I can't imagine that the (7mm/0.25") shorter plug would help. The correct NGK plug would be one of the following: BP5ES, BP6ES, BP7ES. I've successfully used all three heat ranges, but I typically run the middle heat range, i.e. the BP6ES.
Hope this helps,
Don
the reccomended plug is the BP5ES and i often run a platinum plug heat 6 just for durability. I think that is something like BPR6EVX BUT IM NOT SURE ON THAT ONE.
Bob
