March 28, 200620 yr Just won this: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...AMEWN%3AIT&rd=1 any idea on what could be wrong with it? Many Thanks James
March 28, 200620 yr Author what about the noise from the motor? Also why would it start ok when its warmed up Many Thanks James
March 28, 200620 yr When its warm everything will have been moving and be free, When cold everything gets going at once so will be harder (not sure but sounds like it is this) The noise could be anything- bearings, piston knocking etc
March 28, 200620 yr Author do you think its just the kickstart gear and it wont have damaged anything else?
March 28, 200620 yr Looks like a bargain and the guy's not hiding anything mate, at that price you can afford to put everything back to 100%
March 28, 200620 yr Most of the earlier Sherco`s have a very noisey clutch which is perfectly standard and is often misinterpreted as "engine noise". Start the bike and let it warm up then pull in the clutch lever, if most of the noise disappears then you just enjoy your bargain!!! regards Howard
March 28, 200620 yr If at worst you had to rebuild the motor it still would be reasonable.Seller sounds straight,he says it goes well,if you get away with just sorting the kickstart its an absolite bargain,go have alook,he says you can walk away if you don't like it,can't lose is my view
March 29, 200620 yr Looks like a bargain and the guy's not hiding anything mate, at that price you can afford to put everything back to 100% <{POST_SNAPBACK}> Ditto What ya waitin' for?
