October 19, 20242 yr Hello to all ,,a newbie to suspension setup Need some basic advice for suspension setup ,,from the shop front fork damping was fully wound out 32 clicks ,i wound all the way in then backed it out 10 clicks as a starting point ,opinions about this Front preload ,was all the way out ,wound it 7 full turns in then backed out 3 full turns, And havent touched the rear yet but what would be a good starting point Would appreciate any advice ,regards steve
October 19, 20242 yr For preload lookup how to set sag. For the damping is largely personal preference, and it's hard to suggest a number of clicks as a starting point especially since the forks might not even have the standard grade of oil in them. I'd suggest trying it fully out, fully in, and half way to get a feel for it then adjust from there.
October 25, 20242 yr https://betausa.com/support/ Has everything you need, manuals, suspension supplements
October 25, 20242 yr Author Thanks for the info , what's really needed is how many turns to set the rear shock to standard setting on preload , also it states that you can have up to 10 turns for front fork preload in the manual but it is only possible to get 7 full turns
October 25, 20242 yr I doubt there's a standard preload but even if there is you don't want it, you want the right amount of sag.
October 26, 20242 yr On 10/25/2024 at 3:41 AM, betaflaxton said: Thanks for the info , what's really needed is how many turns to set the rear shock to standard setting on preload , also it states that you can have up to 10 turns for front fork preload in the manual but it is only possible to get 7 full turns What year is your BETA EVO.
