frankie422 Posted 21 hours ago Report Share Posted 21 hours ago hi will a ossa gripper 350 cylinder liner work in a ossa mar 350 cylinder . Quote Link to comment Share on other sites More sharing options...
woody Posted 18 hours ago Report Share Posted 18 hours ago The only similarity is the bore size, the porting is completely different in either cylinder 1 Quote Link to comment Share on other sites More sharing options...
frankie422 Posted 8 hours ago Author Report Share Posted 8 hours ago 9 hours ago, woody said: The only similarity is the bore size, the porting is completely different in either cylinder ok thank you , do you also know what gearbox oil they take and what premix ratio i was told 50/1 .thanks Quote Link to comment Share on other sites More sharing options...
woody Posted 2 hours ago Report Share Posted 2 hours ago Manual specifies SAE 80, or any modern light gear oil will work. 1 litre, but 900cc for an oil change as not all of the oil drains out 50:1 is ok with modern synthetic or semi-synthetic such as Castrol Power 1 Quote Link to comment Share on other sites More sharing options...
