Martywill Posted 1 hour ago Report Share Posted 1 hour ago Anybody know where I can find the workshop specs or manual for a 2004 Sherco st 250? I started looking for fork oil capacity but not much found for correct year. Quote Link to comment Share on other sites More sharing options...
RonH Posted 19 minutes ago Report Share Posted 19 minutes ago 1 hour ago, Martywill said: Anybody know where I can find the workshop specs or manual for a 2004 Sherco st 250? I started looking for fork oil capacity but not much found for correct year. Modern Sherco ST 250 trials bikes (equipped with Tech or Paioli forks), the typical fork oil capacity is approximately 250cc to 300cc per leg of SAE 5 or SAE 7.5 weight oil. However, it is highly recommended to set the oil level by height (usually 110mm-130mm from the top, compressed, without springs) rather than just volume for accuracy. Quote Link to comment Share on other sites More sharing options...
