New alloy rear sprocket
Hi All,
I am in need of a new alloy ( if possible ) rear sprocket for my 1969 AJS 37AT that I am busy building. I have attached a sketch of what I need. If I can get only get one that is close, then I am sure I can modify it to suit.
The existing sprocket has been made from two steel sprockets and weighs the same as a baby hippo !!
Has anyone had a bespoke sprocket made, and if so, where. Or can anyone point me in the right direction.
Thks
Bruce Watts
AJS 37A Rear Sprocket.pdf
Look on eBay for a sprocket blank you find the number of teeth and pitch but they normally have a small centre hole then get it machined out to suit your hub
