When Is A Disc A Floating One ?
I know its a floating one when it moves so dont start !
BUT
im doing up a 1993 GG GT25, and i wondered if the disc is supposed to move or its excessive wear ??
i ask because its got loads of jagged teeth which interlock on the hub and disc, but theres play,
is it supposed to be there? OR is it just wear ??
Mat
If theres play when the teeth are locked one way then thats play but if ur just moving the disc back and fourth then it locks and unlocks.
Excellent FF !!
Thank you ! much appreciated
Ive got to really plod on and get some work done on it, when ive done my exams, as i want it for a spare in summer.
BTW FF,
Do <mention of this company is not permitted on Trials Central> play with E-metal and a TIG Welder (ally) as i need abit done on my engine casing before i build it up.
I keep bringing this engine in lol
:P
OKie i will do !
Last exam is on the 31 of may ! woohoo..
I just need a little line of weld on the back of the engine where the swingarm bolt goes through, and also there is a small crack where the clutch slave attaches, which mean i had to tap a new hole, it still works,.......
Just thought id get it done if it was worth it and seeing as tho i've spent so much on it !!
(but ill bring it in)
Mat
